Fake Wall Generating Below Railing
BortDesign
I have tried just about everything to correct these walls genrating below this balcony. I have copied a railing that is working properly right next to it and it is still causing a glitch. I have tried connceting the walls differently in the corner and ran into a road block. I also tried to change the strucure setting called "Stop at Floor Below" and it fixes most of it but shows a corner hanging down. All assistance is appreciated.
14 hours ago, mthd97 said:
Have you tried using invisible walls and or creating a room underneath the balcony and calling it open below for starters ?
Thank you for the response. I have attempted to do the invisible walls as well as having it open. My current workaround is using a landing as the balcony for now.
