Designer_Maddee Posted June 24 Share Posted June 24 When I use CPU ray trace my crown always looks like it has lighting peaking between the bottom and the top of the cabinet. It does it if I add the crown as trim or add it in the cabinet component. I am using x15 on a 2025 Macbook Pro M4. Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 24 Share Posted June 24 47 minutes ago, Designer_Maddee said: When I use CPU ray trace my crown always looks like it has lighting peaking between the bottom and the top of the cabinet. It does it if I add the crown as trim or add it in the cabinet component. I am using x15 on a 2025 Macbook Pro M4. I would strongly suggest switching to x16 and then use the PBR raytrace option which subsequently fixes the light bleed issue. OR it might be fixed if you add a roof 1 Link to comment Share on other sites More sharing options...
Designer_Maddee Posted June 24 Author Share Posted June 24 23 minutes ago, Renerabbitt said: I would strongly suggest switching to x16 and then use the PBR raytrace option which subsequently fixes the light bleed issue. OR it might be fixed if you add a roof Thank you so much! I will move it into x16! Link to comment Share on other sites More sharing options...
