Ed_Orum Posted May 15 Share Posted May 15 Now that I know I can easily save my X17 files to drop box (I am too old to change) I found another problem. When I deleted the wall framing, all the walls got deleted along with the framing. I never had this happen in X16. Does anyone know if the "delete wall framing" works differently in X17 than it did in X16? Thanks in advance, Lane. P.S. So far the only advantage I can see in X17 is that the foundation does not include the sill plate. Link to comment Share on other sites More sharing options...
mLongChief Posted May 15 Share Posted May 15 10 minutes ago, Ed_Orum said: When I deleted the wall framing, all the walls got deleted along with the framing. I never had this happen in X16. Does anyone know if the "delete wall framing" works differently in X17 than it did in X16? I'm not sure what your referring to for "Delete wall framing", but I'm assuming it's the Wall Framing option within the Delete Objects Dialog. If not, what tool are you referring to? At least the Delete Objects Dialog shouldn't be any different in X17, at least to my knowledge. I'm not able to reproduce it with the dialog, do you have a plan that this problem occurs in? Though I'd reach out to tech support, as they could figure out why this is happening, or determine that it is a bug with the software for us to address. Link to comment Share on other sites More sharing options...
