PitMan71 Posted April 24, 2025 Share Posted April 24, 2025 Good morning all I have a project with a fence that attaches to the home. For some reason just under the eave at where the fence intersects the house there is a wall artifact. Anyone know how I can suppress it? See attachment. the place I am referring to is on the left side of the home near the ac unit up underneath the eave edge. Can be seen clearly in 3d view. thanks in advance for the help. Shane 188WindwardReno 3.plan.zip Link to comment Share on other sites More sharing options...
tundra_dweller Posted April 24, 2025 Share Posted April 24, 2025 Hi Shane, one thing you can do is go into your wall definition for that fence and change the material from fir framing to insulation air gap. It doesn't change the look of your fence since you are using panels with their own materials for the fence. I'm not sure why Chief does this kind of thing with walls and wall intersections. 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted April 24, 2025 Author Share Posted April 24, 2025 Thanks.... This is a good work around. I might run this up the flagpole to support just to see what they say about it. Link to comment Share on other sites More sharing options...
