LancasterLinda Posted April 11 Share Posted April 11 Hello all! I am drawing a multi-level deck for a contractor and am trying to lower one of these decks. However, when I lower the "floor" in the dialog box the system lowers the handrail, NOT the deck. It sinks the handrail into the deck planks. Any clues or thoughts on how to fix this? I'm using Home Designer Pro 2025 and work on an MSI laptop. Thanks in Advance!! Linda Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 11 Share Posted April 11 The proper forum for your product can be found here... https://hometalk.chiefarchitect.com/ That being said, it sound like you probably have Auto regenerate deck framing toggled off (assuming your product has that or a similar setting)... Toggle it back on and your decking should move with the room. Link to comment Share on other sites More sharing options...
LancasterLinda Posted April 13 Author Share Posted April 13 OMG!!! That worked!!! Thank you! I did "reframe" the deck (using the icon at the bottom of the page) after each time I lowered it in the dialog box but to no avail. It worked when I toggled on Auto Regenerate. Interesting. Also, thanks for the redirect to use the HomeTalk Forum. But I got my answer from you! Thanks again, Linda 1 Link to comment Share on other sites More sharing options...
