When Lowering a deck, the handrails lower, not the deck
LancasterLinda
Hello all!  I am drawing a multi-level deck for a contractor and am trying to lower one of these decks.  However, when I lower the "floor" in the dialog box the system lowers the handrail, NOT the deck.  It sinks the handrail into the deck planks.  Any clues or thoughts on how to fix this?
I'm using Home Designer Pro 2025 and work on an MSI laptop.
Thanks in Advance!!
Linda
OMG!!! That worked!!! Thank you!
I did "reframe" the deck (using the icon at the bottom of the page) after each time I lowered it in the dialog box but to no avail.  It worked when I toggled on Auto Regenerate. Interesting.
Also, thanks for the redirect to use the HomeTalk Forum.  But I got my answer from you!
Thanks again,
Linda
