RBSdrafter Posted April 10, 2025 Share Posted April 10, 2025 Hello all, I recently started a thread about problems with my curb cutting for driveways. @Michael_Gia gave me the idea of using 3D molding to make the curb so that it behaves predictably and I am able to edit it as needed unlike the automatic curb. After messing with molding polylines and settings I am stumped again. I was able to create the curb for all of the untouched portions of road, but I can't seem to figure out how to show the transition between the normal curb to the driveway, similar to the look for the automatic curb cutting. So far, all I can get is like the picture above, where the curb abruptly ends. I tried putting a 1/16th high strip of molding (the white bar in the picture) in between to show some sort of transition but no dice. I've attached the small plan I made to work with this problem.Driveway Curb.plan Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 10, 2025 Share Posted April 10, 2025 uncheck curbs for the road. only use the molding for the entire curb. add breaks where you want the molding/curb to graduate down to street level. In a cross section, shape the molding as desired to create the lowered curb etc... Not sure if I explained myself correctly. there's a video of this floating around, probably from René or Alaskan son or someone else. Link to comment Share on other sites More sharing options...
RBSdrafter Posted April 10, 2025 Author Share Posted April 10, 2025 41 minutes ago, Michael_Gia said: uncheck curbs for the road... Thank you again! I'll be checking out that video if I can find it. Link to comment Share on other sites More sharing options...
Opondo Posted April 10, 2025 Share Posted April 10, 2025 use line work to trace along the side you want then convert it to road curb Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 11, 2025 Share Posted April 11, 2025 @RBSdrafterHere is one video where René is using a moulding to generate a sidewalk. This is a little more involved than what you are looking for but the procedure is the same for a simple curb. Link to comment Share on other sites More sharing options...
