Ringos Posted March 3, 2025 Share Posted March 3, 2025 It seems like Chief would have a great looking set of American Trees and plants. Common ones that are found in many yard in the US. This way you could use the common flowers that landscapers use in 3d. Oak: Known as the national tree of the United States Ash: A common hardwood tree in North America Cherry: A common hardwood tree in North America Maple: A common hardwood tree in North America Poplar: A common hardwood tree in North America Red Maple Loblolly Pine Sweet gum douglas fir Quaking Aspen sugar maple bossom fir flowering dogwood lodgepole pine white maple basswood elm hackberry etc Bushes Low Scape Mound® Aronia North Pole® Arborvitae Pugster Blue® Butterfly Bush Sprinter® Boxwood Smooth Hydrangea etc. flowers Rose Chrysanthemum Gerbera Poppy Tulip Hibiscus Sunflower Lilac Marigold Lamium/Dead-nettles Datura/Devil's Trumpet Columbine Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 3, 2025 Share Posted March 3, 2025 We actually already have most of those. You should check out the Plant Chooser under Terrain>Plant>Plant Chooser You can search using the Common name and then view results using either the Common Name or the Scientific Name (which is how the plants are named in the library). And if the Library Window is already active, you'll see the Library item automatically selected when you select through the Plant Chooser... Link to comment Share on other sites More sharing options...
