woodcraftdesign Posted February 18, 2025 Share Posted February 18, 2025 In the Midwest when we use 2) 2x10s or 2)lvls we nail them tight together with a specific nailing pattern. Most of the time these are nailed to the bottom side of the top plate. Headers up tight to the top of the wall. We add a plate to the bottom of the header and this forms the top of the window RO. The remaining 2.5 inches on the interior is insulated. Chief defaults to a split header or a hollow header. Can I change this? Link to comment Share on other sites More sharing options...
tundra_dweller Posted February 18, 2025 Share Posted February 18, 2025 There are pretty robust header framing options in the default door/window settings, or you can set individually per opening too. Link to comment Share on other sites More sharing options...
