Gtomer Posted January 19, 2025 Share Posted January 19, 2025 Hi, Making the jump from Revit and so far loving it. My question today is about Elevation tags. I set up my Layout sheet with the Macro on the page number as such A%page% Intent being to insert an "A" before the sheet number (common where I am at to differentiate architectural from other types of sheets) In layout it works perfectly, displaying the letter "A" with sequential numbers as I hit the arrow buttons and move through sheets. However on my Callout Elevation Tags the letter "A" is missing from the sheet info Attached is a COMPOSITE image of my page number not matching the callout. The callout actually lives on a different sheet. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 20, 2025 Share Posted January 20, 2025 Where exactly are you putting that "A%page%" macro? I'm assuming that you're putting it on the actual layout page somewhere as a text box. What you probably should be doing is going to your layout page, clicking the Edit Page Information tool, and then putting "A#" into the Label field. Then back on page 0 (or on your template page), place the %layout.label% macro where you currently have "A%page%". What you're currently seeing is that Chief with automatically label those camera callout labels using the actual sequential page number unless you have a Layout Page Label specified. If you specify a label, then it will use that instead. In the Layout Page Label, you can specify any desired prefix followed by the # symbol and Chief will automatically number any pages with that that same prefix, so if you have 3 pages labeled "A#", they would show as A1, A2, and A3 and you would see the same thing in your callout. You can use a different prefix on another page for example ("S#") and the numbering will start back at one (S1, S2, S3, etc.). Link to comment Share on other sites More sharing options...
Gtomer Posted January 20, 2025 Author Share Posted January 20, 2025 That was it! Thank you for your help! Link to comment Share on other sites More sharing options...
