BrianMSmith Posted January 8, 2025 Share Posted January 8, 2025 First off, please forgive me if this has already been suggested as I am a new Chief user, but have been using AutoCAD since 1988. I would like to see an additional stretch plan added to be able to stretch columns or other objects such as the one in the attached image. Selecting 2 stretch areas is great, but for this example (which we use often) the 3rd seems to have no function. Adding a 4th would allow stretching between two different areas of the object while keeping the other area intact. Let me know if I need to provide more detailed info. Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 8, 2025 Share Posted January 8, 2025 2 hours ago, BrianMSmith said: First off, please forgive me if this has already been suggested as I am a new Chief user, but have been using AutoCAD since 1988. I would like to see an additional stretch plan added to be able to stretch columns or other objects such as the one in the attached image. Selecting 2 stretch areas is great, but for this example (which we use often) the 3rd seems to have no function. Adding a 4th would allow stretching between two different areas of the object while keeping the other area intact. Let me know if I need to provide more detailed info. See attached video for solution on what you are asking for: 250108.mp4 1 Link to comment Share on other sites More sharing options...
BrianMSmith Posted January 8, 2025 Author Share Posted January 8, 2025 Genius! Thank you so much for the option. Link to comment Share on other sites More sharing options...
