ByronVallis1 Posted January 6, 2025 Share Posted January 6, 2025 I've designed a simple house made with ICF walls and wood trusses. I want to add a 2x12 mudsill/top plate to the ICF walls, but I'm having trouble with the trusses bearing on top of the mudsill. I made a wall type, and I can add the mudsill by using a Wall Cap, but the trusses seem to ignore the Wall Cap. If I convert the concrete layer to a framing layer with a top plate, it doesn't seem to build a top plate. I've used manual trusses and am rebuilding framing after each change. Other changes render fine. Any ideas on how to add a wood top plate to an ICF wall, and have the trusses move up 1.5" to bear on the top plate? Regards, Byron Link to comment Share on other sites More sharing options...
Solution ValleyGuy Posted January 6, 2025 Solution Share Posted January 6, 2025 15 minutes ago, ByronVallis1 said: Any ideas on how to add a wood top plate to an ICF wall, and have the trusses move up 1.5" to bear on the top plate? I happen to be working on one right now. Just make a pony wall with the upper wall 1.5" lower than your wall height. Mine is on the second floor so that is why my elevation of lower wall top is so high. Link to comment Share on other sites More sharing options...
ByronVallis1 Posted January 6, 2025 Author Share Posted January 6, 2025 Thanks for the suggestion ValleyGuy, using a pony wall as a mudsill/top plate works pretty well. I added exterior and interior finish layers to match the main ICF wall below, and adjusted the heights of the walls and roof planes, and it all lines up. Thanks! Link to comment Share on other sites More sharing options...
KittleDesign Posted September 10, 2025 Share Posted September 10, 2025 Just wanted to say thanks, this helped me solve my ICF problem too. 1 Link to comment Share on other sites More sharing options...
robdyck Posted September 11, 2025 Share Posted September 11, 2025 21 hours ago, KittleDesign said: this helped me solve my ICF problem too Oh just you wait! There will be more! Link to comment Share on other sites More sharing options...
