LGallagher Posted November 25, 2024 Share Posted November 25, 2024 Does anyone know how I can place a Witch Window? I'm using CA Premier 16? I didn't realize until just now that this is a Vermont thing. Probably no one else except Vermonters would know what I'm talking about. I'm doing as-builts for a house with a Witch window and it would be great if I could get it in there for the renderings. Any help would be apprecited. Thanks Link to comment Share on other sites More sharing options...
Rich_Winsor Posted November 26, 2024 Share Posted November 26, 2024 This is asbestos I could come up with using the Windows tools. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted November 28, 2024 Share Posted November 28, 2024 OK, so here's the work around: Draw a wall segment and install a window in it. Highlight the Window and in the Window DBX set all the parameters for the window you want. While the Window is selected use the Convert Selected to Symbol tool to add the window to your User Catalog. Now use Robert Lackore's excellent description below to create the angled hole in your wall. You can now install the window symbol from your library into the hole. The Window Symbol can be rotated to match the hole while a Window can't be rotated. 1 Link to comment Share on other sites More sharing options...
