KecoLo_Design Posted Tuesday at 04:08 PM Share Posted Tuesday at 04:08 PM Hello dear community, I am looking for a garland light to add to my project. Could anyone direct me to an existing symbol? Many thanks!! Link to comment Share on other sites More sharing options...
ericepv Posted 16 hours ago Share Posted 16 hours ago Rather than trying to find a symbol, you could make your own using a distributed objects region or path (Build / Distributed Objects). Here's one I made in about a minute using a Spline Distribution path. I populated it with 3" spheres with the material properties set to transparent (Crown Glass) and emissiveness set to the maximum. You can give it any color you like. - Eric 1 Link to comment Share on other sites More sharing options...
KecoLo_Design Posted 15 hours ago Author Share Posted 15 hours ago 1 hour ago, ericepv said: Rather than trying to find a symbol, you could make your own using a distributed objects region or path (Build / Distributed Objects). Here's one I made in about a minute using a Spline Distribution path. I populated it with 3" spheres with the material properties set to transparent (Crown Glass) and emissiveness set to the maximum. You can give it any color you like. - Eric Thank you very much for this suggestion Eric. I will test this technique !! Link to comment Share on other sites More sharing options...
