BortDesign Posted November 6, 2024 Share Posted November 6, 2024 Not sure what is causing this because I haven't had this issue until today but when I am looking outside through a window it is very pixelated. As soon as I step through the window the trees and visual lines don't look pixelated. If anyone has come across this I would greatly appreciate the help. Thanks. Link to comment Share on other sites More sharing options...
Renerabbitt Posted November 6, 2024 Share Posted November 6, 2024 please provide a screenshot of your rendering technique options window Link to comment Share on other sites More sharing options...
BortDesign Posted November 6, 2024 Author Share Posted November 6, 2024 Thank you for the response. Here are the rendering technique options and active view. Link to comment Share on other sites More sharing options...
Solution Ryan-M Posted November 6, 2024 Solution Share Posted November 6, 2024 The pixelation through the windows in your first two images look similar to an issue that we addressed in the 26.2 release. I believe you can still get it to happen, but my understanding is that it will only happen if your plan is very far from the origin so that might be something to check. In your last image with the water, it looks like poor denoising (on the water itself). X16 sometimes struggles to remove noise on transparent (refractive) surfaces. We expect this to be improved in X17. 1 Link to comment Share on other sites More sharing options...
