Renerabbitt Posted October 24, 2024 Share Posted October 24, 2024 I've been using a custom trained AI bot for a few years now. I've got 1000's of hours into its instruction set. It does a pretty decent job with beginner and intermediate scripts and at times can even get you to a complex script if you know what you are doing. It will be a learning process, AI isn't perfect and it will need context at times, but It's free to use and it drives traffic my way. Enjoy! Check it out here:https://www.rabbittdesign.net/macros 1 Link to comment Share on other sites More sharing options...
ChrisOtt Posted January 1, 2025 Share Posted January 1, 2025 On 10/24/2024 at 3:21 PM, Renerabbitt said: I've been using a custom trained AI bot for a few years now. I've got 1000's of hours into its instruction set. It does a pretty decent job with beginner and intermediate scripts and at times can even get you to a complex script if you know what you are doing. It will be a learning process, AI isn't perfect and it will need context at times, but It's free to use and it drives traffic my way. Enjoy! Check it out here:https://www.rabbittdesign.net/macros I will check it out, and hopefully lean on it hard. I'm a Ruby Newbie... Link to comment Share on other sites More sharing options...
DenandBurrow Posted May 16, 2025 Share Posted May 16, 2025 God bless you, sir! Super new to running Ruby scripts. Is there a quick guide on it for Chief? Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 16, 2025 Author Share Posted May 16, 2025 1 hour ago, DenandBurrow said: God bless you, sir! Super new to running Ruby scripts. Is there a quick guide on it for Chief? There is a tutorial in the program that is very basic and a section the manual but not much else. I saw the chat log, ruby can't do anything programmatically for you so the bot gave you some accurate info albeit a slow method for relinking layout. While in layout you should go to tools menu then layout then referenced plan files to change the reference plan being used to your active plan 1 Link to comment Share on other sites More sharing options...
