Seeking services to take my plan and build views needed for county approval and working construction drawings
I've got a 3-car garage plan that is nearly complete.  I'm stuck a little bit on the slab with footers, regarding slab height, and whether the block pony wall overlaps the slab.  I'm also not finished with wall section view.  I just don't know what is customary.  I've presented my intentions pretty well in the plan.  Wonding if someone can take a look at my plan and come back to me with a quote that will get it finished, and ready to be presented for approvals and bids.  I also cannot get the framing views to show the pony block walls below down to the slab, no matter what I do.  I don't need a truss plan, as the builder will get the truss company to engineer that.
It's in Home Designer Pro 2024.  the Home Designer website took me here when I clicked on services.  I understand this will import into Chief Architect.  I did post a similar email once before, but the gentleman who responded, for whatever reason we were unable to reconnect.  Electrical plans apparently are not required.
Thank you.
Mike Baglini
Baglini Garage July.plan
