Exporting from Chief to DWG
BruceYYC
I need to export a Chief !5 drawing that has pdf's built into it. When I export the DWG I loose all of the pdf's and only get the lines and images done in Chief.  I loose any google earth, company logo and imported pdfs. How do I get everything to translate to DWG?
DWG only supports vector graphics, so a PDF that is raster-based won't export. Here is what Chief supports during DWG import - I suspect export is similar:
Thanks, can you suggest a better way to achieve results that my clients can use? I suggested to my clients that they import my pdf into their program as an image. Sometime that seems to much for the basic user.
Regards,
Bruce
