BruceYYC Posted May 18, 2024 Share Posted May 18, 2024 I need to export a Chief !5 drawing that has pdf's built into it. When I export the DWG I loose all of the pdf's and only get the lines and images done in Chief. I loose any google earth, company logo and imported pdfs. How do I get everything to translate to DWG? Link to comment Share on other sites More sharing options...
rlackore Posted May 20, 2024 Share Posted May 20, 2024 DWG only supports vector graphics, so a PDF that is raster-based won't export. Here is what Chief supports during DWG import - I suspect export is similar: 1 Link to comment Share on other sites More sharing options...
BruceYYC Posted May 22, 2024 Author Share Posted May 22, 2024 Thanks, can you suggest a better way to achieve results that my clients can use? I suggested to my clients that they import my pdf into their program as an image. Sometime that seems to much for the basic user. Regards, Bruce Link to comment Share on other sites More sharing options...
