RGShurlingPA Posted May 18, 2024 Share Posted May 18, 2024 I have an issue that often when I create a monolithic slab under the first floor, that it does correctly build the slab and footers I have specified in 2D. When I then go to the 3D view the slab is visible, but not the footer which is on the layer Foundation Walls. I have checked in my 3D view that layer is turned on, but it does not appear and I get an opening in the terrain that is white where the footings should appear. Any advice would be greatly appreciated. Thanks, Roy Link to comment Share on other sites More sharing options...
RGShurlingPA Posted May 18, 2024 Author Share Posted May 18, 2024 Well after a bit more effort I discovered that the slab wall was turned on during foundation generation, but footings was not checked. Problem solved. Link to comment Share on other sites More sharing options...
