cbucks Posted April 5, 2024 Share Posted April 5, 2024 Is there a keyboard command to select the entire floor elevation for a plan with multiple structures? Link to comment Share on other sites More sharing options...
tundra_dweller Posted April 5, 2024 Share Posted April 5, 2024 Without knowing exactly what your goal is here, you could select (highlight) a room in your plan, and then on your edit toolbar find the "Marquee Select Similar" tool and click that once: After you click that tool button, you should get another option on that toolbar to "Select all Similar", click that: After you do that it should have selected all of the rooms in all of the structures on that floor of the plan, from there you can edit all of their floor elevations to be the same value. Link to comment Share on other sites More sharing options...
cbucks Posted April 20, 2024 Author Share Posted April 20, 2024 Th On 4/5/2024 at 5:01 PM, tundra_dweller said: Without knowing exactly what your goal is here, you could select (highlight) a room in your plan, and then on your edit toolbar find the "Marquee Select Similar" tool and click that once: After you click that tool button, you should get another option on that toolbar to "Select all Similar", click that: After you do that it should have selected all of the rooms in all of the structures on that floor of the plan, from there you can edit all of their floor elevations to be the same value. That works perfectly thanks! Link to comment Share on other sites More sharing options...
