robdyck Posted March 22, 2024 Share Posted March 22, 2024 Section View Room Label Library Symbols Attached! There are 2 symbols, one for simple placement in section view and one for simple placement in plan view. Keep in mind, it's not a perfect world...in any section or elevation view, if the camera sees the object, the label will display! Simply select the object in the library and click away in your active view for instant gratification! The object is on the Material Region layer. The object label is on the Room Label layer. Edit settings to suit your needs. TIPS: Place these room labels once your section views are determined. For the Wall Insert, place it in a section view. It will insert into a wall and will not be visible. Subsequently, It also might be a bit tough to select in that view! But this will be the fastest way possible to identify rooms in section view. For the Room Insert, place it in plan view, either centered in a room or just in front of your section cut line. In Plan View, the labels have been offset. You can very easily select the object by clicking on the label!! RDBD-ROOM LABELS.calibz11.18 kB · 0 downloads 1 1 Link to comment Share on other sites More sharing options...
