Auto-build addition roof without modifying existing
I've modeled an existing house with a fairly complex roof in a drawing file.  I now need to show a fairly extensive addition on this house.  I want to leave the existing roof model completely untouched then use auto build on the addition roof.  Is the appropriate move to make the existing house a block in the drawing (sounds too simplistic)?  Or make a model in this drawing file, start a new one for the addition and place the existing model in there?
What I would do is keep the existing plan file as your as-built, then save new copy of the as-built plan for addition, model your addition as needed with auto roofs as far as you can in the addition plan, and let the existing roof do what it will. Once you get the addition roof how you want it, make sure auto roof build is off, delete the "new" roof planes on the existing part of the home, and copy-paste in place all the roof planes from your as-built plan into the addition plan.
