Foundation not building
winterdd
Hey guys, I have attached a quick sample of what I am having issues with all of a sudden with monolithic slabs. It won't build with a brick ledge and nothing shows up on level 0. I went thru my settings on the "brick 4" wall and cannot see where anything is wrong.
mono issues.plan
17 minutes ago, tundra_dweller said:
Try opening up the room spec for the living room and make sure "Build Foundation Below" is checked in the Structure > Floor settings, then rebuild the foundation with the add foundation button.
That was it, not sure why that was unchecked but glad it was an easy fix. Thanks!
