JKEdmo Posted February 21 Share Posted February 21 Good afternoon, Laying out a curved stair. How can define the overall run of the stair to be exactly 90 degrees? As you can see, the stair below is close, but slightly off. I must be overlooking a setting or unclear on technique. Thanks again, Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted February 21 Author Share Posted February 21 I figured it out (pats self on back). I had "Lock Tread Depth" checked. This fixed the run length of the stair. So, I unchecked "Lock Tread Depth" and instead checked "Lock Number of Treads." This allowed me to adjust the curved stair drag points to some cad helper lines I drew. Jim Link to comment Share on other sites More sharing options...
