TeaTreeT Posted February 20, 2024 Share Posted February 20, 2024 Hello! I'm hoping to get some assistance. I'm not overly familiar with the terrain tool, and working on a project that has a slope from road side down to waterside. There is a walkout basement under the deck, and a gentle slope away from the garage to allow for driving out with a lawn tractor or to pull a boat down to the water. I think I have it fairly close, but the spot where the retaining wall is, the grade keeps staying higher than the door. Hopefully someone has input as to what I'm doing wrong! I have attached the chief plan as well as snips of the working drawing set that indicate what it should look like. Thanks in advance Portage Bay 3D.plan Using Chief Architect Premier X15 Portage Bay 3D.plan Link to comment Share on other sites More sharing options...
robdyck Posted February 20, 2024 Share Posted February 20, 2024 The choice to use terrain modifiers like lowered regions isn't the best option. I've deleted the lowered regions and replaced them with 2 Elevation Regions, both of which are shaded and have there elevations displayed. This is a very quick and simplified demonstration, but I'd suggest you give the elevation regions a try. Link to comment Share on other sites More sharing options...
TeaTreeT Posted February 20, 2024 Author Share Posted February 20, 2024 Thank you so much, Rob! That tool certainly made it a lot easier. Link to comment Share on other sites More sharing options...
