MEH_Natalie Posted January 30, 2024 Share Posted January 30, 2024 Hello All, I have been trying to fix this random roof over hang and I feel like i have tried everything but no luck. - the roof plane looks fine, however, when the layer Roof Overhang is toggled on you can see that there's one random section of the roof - I tried connecting all the roof plane to ensure that they are connected properly and on the same plane - I tried redo-ing the entire roof Can anyone offer advice? I have also attached the plan here. X15 Window 10 Roof issue - fix.zip Link to comment Share on other sites More sharing options...
VHampton Posted January 30, 2024 Share Posted January 30, 2024 All fixed. Roof issue - fix.plan.zip Link to comment Share on other sites More sharing options...
MEH_Natalie Posted January 30, 2024 Author Share Posted January 30, 2024 13 minutes ago, VHampton said: All fixed. Roof issue - fix.plan.zip 6.22 MB · 1 download That's speedy! May I asked which part of the roof went wrong? Or how did you fix this? Link to comment Share on other sites More sharing options...
VHampton Posted January 30, 2024 Share Posted January 30, 2024 Yes... sorry for not adding the details. Per Eric... the auto roofing works incredibly well. My guess is that they were manually constructed perhaps, and this is where that minuscule variation can cause a blip. So you did the right thing in using the rainbow icon to highlight the sheetrock which pointed to the wonky roof. For whatever reason, that section of roof on the left side didn't have a clean edge. When the join roof tool is used, right before they join, look for a slight grey highlight. I could tell that the edge was "off' by the way the left roof kind of turned into a big triangle. (Usually a sign which indicates that you shouldn't join them). Solution... deleted the problematic roof, and copied and pasted the good one from the right side. Problem solved. Link to comment Share on other sites More sharing options...
