Jorgen Posted January 17, 2024 Share Posted January 17, 2024 Hi, Im using a 3D solid to create steel reinforcement (trench mesh with 400 mm high ties). All works (Pls note I dont want to use Chief Architect reo as its not suitable in Australia). The issue I have is I'd like to pick up the length and use in Materials. I can get the perimeter displayed via components dialog using =visible_length.... I now need to get this to length (m). The trench mesh is 200 mm wide .... so the formula should be (visible_length-0.2-0.2/2.....however this errors. Any suggestions welcome. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 17, 2024 Share Posted January 17, 2024 Does this work for you ? Link to comment Share on other sites More sharing options...
