wkshank Posted November 13, 2023 Share Posted November 13, 2023 Normally if I draw a rectangle, when I click on one side of it, the dimension across to the other side will appear. Sometimes it just doesn't show up, which is highly inconvenient. I have saved, shut down, started my computer up again, and it is still doing this (or NOT doing it, which is the problem). It doesn't matter what file I open... in other projects the program is giving me the same problem. Is there a setting where this feature is turned on and off? (why would anyone ever want to turn this off??) Haaallllpp. (Edit: ALSO - not showing distances for anything, really -- click on a wall and it does not show distance to nearby parallel wall.) Wendy Shank - Chief x14 Link to comment Share on other sites More sharing options...
Renerabbitt Posted November 13, 2023 Share Posted November 13, 2023 On 11/13/2023 at 5:05 PM, wkshank said: Normally if I draw a rectangle, when I click on one side of it, the dimension across to the other side will appear. Sometimes it just doesn't show up, which is highly inconvenient. I have saved, shut down, started my computer up again, and it is still doing this (or NOT doing it, which is the problem). It doesn't matter what file I open... in other projects the program is giving me the same problem. Is there a setting where this feature is turned on and off? (why would anyone ever want to turn this off??) Haaallllpp. (Edit: ALSO - not showing distances for anything, really -- click on a wall and it does not show distance to nearby parallel wall.) Wendy Shank - Chief x14 Expand T is the hotkey for temp dimensions, are you possibling turning that off? Link to comment Share on other sites More sharing options...
wkshank Posted November 13, 2023 Author Share Posted November 13, 2023 Well good grief. Yes. I had no idea. I don't use hotkeys at all because... well because I'm an idiot, apparently. I know most on here wouldn't draw without them. Must learn about hotkeys.... Thank you so much. Link to comment Share on other sites More sharing options...
