Morgan_Goodwin Posted May 23, 2023 Share Posted May 23, 2023 How do I create a 2d version of the window used in my plans to draw a Window Detail for the layout? Example attached 1 Quote Link to comment Share on other sites More sharing options...
glennw Posted May 23, 2023 Share Posted May 23, 2023 Try CAD Detail From View? Quote Link to comment Share on other sites More sharing options...
Carudo Posted May 24, 2023 Share Posted May 24, 2023 Hi Morgan Make the elevation view and do transparent the wall, change the elevation in rendering techniques to vector view, send the elevation to the layout select the scale you need and select plot line, check mark in Use Edge and Use Pattern, in the layout cut all and leave only the Window and put all your notes. you can change the wall to normal in the plan done 2 Quote Link to comment Share on other sites More sharing options...
