Wall Niche - Add to Library
ARF_PSG
Hey Chief.  ¿Por Que? no able to add to Library for Wall Niches?  I would think since these fall under the "window" category you should be able to add to library like a normal window.  Is there something I am missing?  As a side note, i have components attached to the niche i want to replicate over and over.
I'm not sure about your components, but here is how I saved it to the library. Place a Wall Niche in plan, select convert to symbol, symbol name Wall Niche, symbol category Fixture Interior, check add to library and show advanced options. Open symbol specifications, in the 3D tab check include size: width & height, in Rotation Z-, in the Options tab, select Insert in Wall 3". Open the wall Niche in the Library Browser, in the Layers Tab select Wall Niches, in the Schedule Tab select include in schedule as, uncheck fixtures and check wall niche in the windows tab.
