Deck issues and bay windows HELP!
BrittanyT
Hello - I am new to Chief Architect and desperately need help figuring out this deck I'm trying to create. When I go to add railings to it, they are floating - which they weren't before. And the structure below is no longer showing up - I would like to have the deck reach the top of the terrain for a clean look. The hot tub is supposed to be sitting on top of the terrain as well, and the deck should be built around it, but I'm not sure how it got raised. The paneling also doesn't look as good as I'd like, but that is not main priority.
I also cannot figure out bay windows...one of the windows has disappeared, and I have the width I need and location of the window where I need it, but the deck is being built around it when I would like it to just continue underneath of it. If there's a way to connect the windows and not have brick in between - that would be great as well - if not, I am open to any help. I have attached the file here. Please help! Thank you!
Landscape Plan Help.planFetching info...
This section is for Requesting Paid Work/Help ........if that's not you ? then copy and paste your Help Request and Plan into the Q+A Thread.
People will also need to know what Version of Chief etc you use , you can add that Via your Forum Sig. so you don't need to do it every post...  see the link below for that.
Mick.
 https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662
*** I think you already did it now....
