Brick Overhangs foundation X14
Johnthree
Chief Architecture Premier X14
Hello, I'm having an issue with the brick overhang the foundation when there is a transition from brick to siding.
The brick return is only supposed to be 2' but shows up on the elevation as longer, it is correct on plan and foundation pages.
I've attached images of everything my current setting and views.
  • 3 months later...
This is because chief is wrapping your brick back to the siding wall. You should create your own return instead by taking the continuation handle of your brick wall and returning it back. See screenshot
