TWIST LOCK RECEPTACLE
Carudo
There are a couple methods:
1.  Edit that CAD Block and simply replace the triangle with this Unicode Symbol:
It works because the symbol is a text object and so the solid "fill" is retained.
2.  Set the Symbol's 2D Block to have a solid Black Fill.  This will likely result in the circle being filled as well, so you'll need to also edit the CAD Block to break the circle.  Easiest way to do this is to replace the circle with 2 arcs and then select one of them and click Disconnect Selected Edge.
