BuilderP Posted March 14, 2023 Share Posted March 14, 2023 I am struggling to figure out how to change the default position of the callout labels in my plan view. All of my window and door callouts are centered on the door/window which makes reading the window callout nearly impossible. Is there a way to have the callouts offset to the side of their object? Link to comment Share on other sites More sharing options...
tundra_dweller Posted March 14, 2023 Share Posted March 14, 2023 Go to the Label tab of your door/window dialog box and adjust the label position using the x-y coordinates. In the future you should post these questions in the Q&A section of the Chieftalk forum. This Tips & Techniques section is for sharing your tips & techniques with others. Also providing the version of Chief you are using in your account signature is helpful for others trying to help you out. Cheers! Link to comment Share on other sites More sharing options...
tundra_dweller Posted March 14, 2023 Share Posted March 14, 2023 1 minute ago, tundra_dweller said: Tips & Techniques section Oops I should have said Symbols & Content section, but same deal. Link to comment Share on other sites More sharing options...
richoffan Posted March 14, 2023 Share Posted March 14, 2023 For fine tuning you'll also see when you highlight a window or door there is a small handle in the center of the label. You can hold down CTRL and adjust from there. We are, however, assuming what program and version you're using...... Link to comment Share on other sites More sharing options...
