DIMENSION DISPLAY SIZE
BAYNEDESIGNLLC03
Go to solution Solved by JKEdmo,
  • Solution
3 minutes ago, BAYNEDESIGNLLC03 said:
It is just when I scroll out the measurements display get larger.
I believe it's caused by this setting under Preferences / Appearance.  If you set it to "0" then text will not adjust when you scroll in or out.
