3DConnexion mouse CA menus
Flash691
Go to solution Solved by Renerabbitt,
I've got an old Space Mouse and a new CAD Mouse pro I wanted to use with CA like I've seen in Rabbit Design's videos. When I try to set up my mouse menu's, I don't have the menu items. I get ChiefArchitech category, but it only shows 3D view options.
The Radial Menus section only has the standard 3DConnexion options.
I've tried reinstalling both CA and the latest mouse drivers. Other applications have different Radial Menus.
Any Ideas would be appreciated.
Thanks,
  • Solution
9 minutes ago, Flash691 said:
Rabbit Design's
This is me, please tag me so I get notifications or quote me...I just happened upon this while taking a break. :)
Those menu items are ones I created myself by writing macros, they are not built in. I hand scripted the icons in place as well. Takes a bit of coding to set it all up. You can write your own macros using the built in recording function. Mine are a bit complicated in that I wrote in modifiers to gain an additional 3 functions per sqipe on the menus. Let me know if you need more info
image.thumb.png.909db4ebad5854316e48918ce73d4114.pngCurrent keybinds
Thank you! In the future I'll figure out how to tag people.
I was thinking(hoping) it was like Sketchup where the functions were all listed with icons and worst case, I'd have to build my own radial menus.
