D_CADK Posted January 12, 2023 Share Posted January 12, 2023 I'm creating a sunroom that has a curved roof made of glass panels (image attached). The skylight function has been great, but I can't seem to find an option to make it curved or fit the roof shape. Is there a way to make a curved skylight in chief architect? Thank you. Link to comment Share on other sites More sharing options...
javatom Posted January 12, 2023 Share Posted January 12, 2023 Set the glass in the curve to "NO MATERIAL". Then you can use an extruded polyline of glass in it's place. 1 Link to comment Share on other sites More sharing options...
D_CADK Posted January 12, 2023 Author Share Posted January 12, 2023 1 hour ago, javatom said: Set the glass in the curve to "NO MATERIAL". Then you can use an extruded polyline of glass in it's place. Took me a bit to learn and figure out extruded polyline, but it seems to work. It does seem to mean that later changes to those skylights will have to be done manually, but that's okay. Thanks! Link to comment Share on other sites More sharing options...
