Wall Cleanup Question
JKEdmo
Good morning,
Quick question about wall cleanup behavior.
I have 3 exterior wall types coming together in a T condition. 2 same and 1 similar (grey fill):
They have their main layers defined as outer face of stud.  I select each separately below to illustrate this:
What I don't understand is why the wall cleanup occurs at the middle of the wall and not at the face of studs of the 3 walls.  In other words, my expectation would be the grey solid would stop at the right side where the intersection of the 3 main wall layers occurs and not in the middle of the tee intersection.
Your insight would be appreciated.
Thanks again,
JIm
4 minutes ago, solver said:
That's a question only someone at Chief will be able to answer.
Are you trying to solve a problem, or are you just curious?
Eric, I suppose curious if this is "normal" behavior or if I'm doing something wrong.
I know about the manual edit layer tool.  So, I know about that fix.
I guess I would have expected automatic cleanup to happen at the intersection of main wall layers...
Thanks, Jim
Hmmm, I'll rephrase. I guess my question is about how Chief resolves these tee intersections.
When my walls are set up with main layers defined like this:
Why does Chief resolve the intersection like this, with an offset intersection.  The 3 main layer planes do not intersect.
Is this a quirk or maybe I'm missing something?  If quirk, maybe the question is more for Chief as you said.
Thanks,
Jim
