JKEdmo Posted December 24, 2022 Share Posted December 24, 2022 Good morning, Quick question about wall cleanup behavior. I have 3 exterior wall types coming together in a T condition. 2 same and 1 similar (grey fill): They have their main layers defined as outer face of stud. I select each separately below to illustrate this: What I don't understand is why the wall cleanup occurs at the middle of the wall and not at the face of studs of the 3 walls. In other words, my expectation would be the grey solid would stop at the right side where the intersection of the 3 main wall layers occurs and not in the middle of the tee intersection. Your insight would be appreciated. Thanks again, JIm Link to comment Share on other sites More sharing options...
JKEdmo Posted December 24, 2022 Author Share Posted December 24, 2022 4 minutes ago, solver said: That's a question only someone at Chief will be able to answer. Are you trying to solve a problem, or are you just curious? Eric, I suppose curious if this is "normal" behavior or if I'm doing something wrong. I know about the manual edit layer tool. So, I know about that fix. I guess I would have expected automatic cleanup to happen at the intersection of main wall layers... Thanks, Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted December 24, 2022 Author Share Posted December 24, 2022 Hmmm, I'll rephrase. I guess my question is about how Chief resolves these tee intersections. When my walls are set up with main layers defined like this: Why does Chief resolve the intersection like this, with an offset intersection. The 3 main layer planes do not intersect. Is this a quirk or maybe I'm missing something? If quirk, maybe the question is more for Chief as you said. Thanks, Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted December 24, 2022 Author Share Posted December 24, 2022 28 minutes ago, solver said: If you will attach a simple plan with these walls, I'll take a look. Thanks. I clouded the intersection. Jim TEST.plan Link to comment Share on other sites More sharing options...
JKEdmo Posted December 24, 2022 Author Share Posted December 24, 2022 Thanks for looking. I'll read up on your tips. Jim Link to comment Share on other sites More sharing options...
