Molding Challenge
designgirl79
Go to solution Solved by Renerabbitt,
Hello all,
I am hoping I can get help on an issue I just ran into doing one of the latest chief bootcamps. I am using X14.  You can see in the attached image that the molding just stops right of the doorway. I am not sure why? Maybe the cabinets on the next wall? Is there a fix or a way to avoid this in the future? Grateful for the help!
  • Solution
Would be nice if you post your plan file, see video below for an awesome way to present your plan challenges.
Only guess would be that you made the cabinets to the right an architectural block and it needs to be exploded.(It looks like the molding is cut to the refer handle)
