CA Version 11- Isolating Drawing Layers on a Layout Sheet
bnharch
I'm having a problem with plans sent to layout sheets. For instance, I send a first floor plan from the Working Layer Set  to a layout sheet and save it the layout as A01. Then I go up a floor to the 2nd floor plan and send that to a new layout sheet and save it as A02 and close it. But, when I go back and open layout sheet A01, it is now displaying the 2nd floor plan, same as A02. How do stop this so that the I can isolate separate level plans from the Working Layer set on separate layout sheets? Thanks
Each would need it own plan view. 'working plan view', 'working plan view 2nd floor', etc. For different layer sets I use the same method (electrical plan, electrical plan 2nd floor). Between the plan view and layer sets you can control the content on the layout sheet.
