MN_JohnH Posted August 15, 2022 Share Posted August 15, 2022 For some reason I can't connect this thicker wall to the wall behind the cabinet and in trying to do so, somewhere along the line it created this invisible wall that I can not delete... Wall issue.plan Link to comment Share on other sites More sharing options...
MN_JohnH Posted August 15, 2022 Author Share Posted August 15, 2022 1 hour ago, solver said: The program automatically creates that invisible wall to connect rooms that do join other walls. Draw your own, place on its own layer and turn off if you don't want to see it. Thanks, seems silly to just create room dividers. Is this new with 14? I am still unable to connect that wall like your drawing shows. I drag it over and it snaps back to the wall divider line and show a yellow exclamation point about unconnected wall. Link to comment Share on other sites More sharing options...
MN_JohnH Posted August 16, 2022 Author Share Posted August 16, 2022 I see now. It just didn't like that I drew a room in the middle of that interior space, (?). So you connect it somewhere else and then it lets you delete the other wall. Guess I have just never come across that situation before. Thanks, Link to comment Share on other sites More sharing options...
