How to Clip Display Reference?
BJYArch
Is there a way to clip a Display Reference?  See image below as an example.
Top Image: I'd like to clip out the Glass House Display Reference where the red outlines are.  [in Autocad it's an Inverse of an XREF Clip]. Ideally both red boxes but just the bathroom would be sufficient.  I've tried sending the Glass House to the back and I am not able to clip the Display Ref independently from the Elevation.
Bottom Image: This is a new wall but an example of how I'd like the top image to look.
Thank you,
This is my first post so I hope my signature shows up correctly.
Edit - my signature didn't appear so pasting it in now.
Brandy
Premier X14
11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz   3.60 GHz
32.0 GB
64-bit operating system, x64-based processor
Instead of turning a display reference on, simply send two layout boxes to layout, one over the top of the other, and clip to your hearts content.
Since this is your first post, please @ mention people or use the quote system if you need to speak to someone specific comment an you want them to be notified
@Renerabbitt Thank you!  That's a great idea!
I also changed the transparency and color of the Display Reference which helped as a work around but not as good as clipping.
(figured out how to get my signature too!)
