Align drawer and door patterns and texture orientation
Jeffcrigler
I am trying to align the orientation of the materials on a base cabinet with both drawers and doors.  When I use the material painter to apply "Teak" for example, to a standard vanity cabinet, the drawers and the doors are always 90 degrees off.  If I rotate thee texture of the cabinet 90 degrees, they both rotate.  I need to rotate the doors or the cabinets separately.  I want both the drawers and doors to have the texture apply in the same vertical or horizontal orientation.
Edited by Jeffcrigler
I have tried copying the material and rotating it.  That works fine.  But I still have the same problem is I apply it to a cabinet which has both drawers and door.  The doors and drawers are always 90 degrees off.  The doors have the grain vertical and the drawers horizontal, or vise versa.
Ive tried this on the standard build cabinets that CA makes, and also on library manufacturers cabinets and get the same results
