contractcad Posted June 23, 2022 Share Posted June 23, 2022 I have a strange predicament, I updated a wall that I had previously framed with new windows and after highlighting the wall, I wanted to reframe it using the radio button in it's command ribbon at the bottom of the window but alas, that particular command is not there. Looking up help it says that to frame a wall it has to have a framing layer to do so which I do believe I have seeing I have already framed the wall once. Also, as a check I created a new identical wall off to the side and highlighted it and magically the frame wall button is there, just not on any of my existing and already framed walls. I am left at a loss as to why and scratching my head here. Link to comment Share on other sites More sharing options...
stephenbc Posted June 23, 2022 Share Posted June 23, 2022 Open your Wall Specification and go to your Structure tab, under Framing. Is the 'Retain Wall Framing' checked? If so, uncheck it and your framing tool will come back. Link to comment Share on other sites More sharing options...
contractcad Posted June 23, 2022 Author Share Posted June 23, 2022 hmm, I think I even remember clicking on that button too Link to comment Share on other sites More sharing options...
