Checklist
Hammer7
...so you have been working on a plan and getting it ready for completion for a set of construction documents...Do you go through it one last time to check it for errors via a personal checklist...?
...walls are all aligned properly, floors are all correct, ceilings are all correct, stairs have been checked
....Roofs are all joined exact?
...everything is locked down?
....Dimensions are correct and the rights size and locations?
....all centering is correct
....window tops, door tops?
I'm trying to create and work off something like this...I know we should be doing this all along but sometime things get missed after a while..
Do you use something like this or would you?
