Request help with roof problem
DRyeHD
I'm designing a small cabin - nothing fancy.  The roof is 1:12 pitch using trusses with a kicker on the front (see attached image).  My local truss company suggested the design.  In between the trusses in the living area, we will use 2x4 nailers (8" from the bottom) to attach the finish ceiling material.
In the process of adjusting the roof, something happend to throw the inside roof beam pitch off.  It seems the roof plane is still 1:12 but I can't figure out how to get the roof beams (which represent trusses) to follow the 1:12 pitch.  Further the roof beams seem to be a different pitch in section 2 than in section 1.  Any input to this problem would be greatly appreciated.  I've attached the zipped .pln file.
Hawley.zip
