Horizontal Framing M1 Mac Issues
dchaley369
Has any one had issues drawing a pole structure with horizontal framing on a M1 Mac.
It appears to me that it does not work.
Too many issues to list, from general framing to framing overview shot.
I have been attempting this for several hours and must move on to hand drawing, deadlines you know.
So I am wondering if anyone else is not able to use it this option on an M1.
Thanks for any input.
Chris @ 3 Rivers
I have been using Chief for since 9.
Started in Windows and switched to Mac.
Hi Solver,
Sorry, It has been years since I last posted a question.
I am using X13 Mac
Issues are many, for example, after defining the wall, when I draw the walls and select framing view to take a look, I get a horizontal white double 4 vinyl siding that covering both exterior and interior walls, even though it is defined as white corrugated steel siding exterior only. There is no framing view as it is a solid block of framing instead of showing the OC posts defined, there is no horizontal framing either just a solid block as the posts even though the layers are defined properly, so and so forth.
I have tried all I know, redlining the wall setting and the default setting but to no avail.
Which made me wonder if there is an issue with the M1, which has been great since I started using it last year.
Thanks
I don't think this has anything to do with the M1 but I don't really have enough information to make any good guesses.
I would recommend that you either post your plan for someone to take a look at or contact tech support for more help.
