caf200 Posted February 23, 2022 Share Posted February 23, 2022 On 2/15/2022 at 7:31 PM, proformacon said: Has anyone with a Mac had issues with rendering? Photo example attached, Also sending a view to layout live sometimes is the same thing or it just gets off halfway, etc. Just upgraded to X13 so would really like a fix if there is one. Just in case... Not sure if you the same options on the mac. I had an issue with my new Surface Pro and had to go to tech support. This was one workaround for my issue. Quote 1. Go to Edit>Preferences 2. Go to the Render panel 3. Check the box for Texture Compression and click OK. I looked up that option in the help (Index tab and render search word) and here is what it said. Quote When Texture Compression is checked, material textures are compressed so that less video memory is required when a 3D view is generated. Texture Compression takes time, however, so view generation will typically be slower. Link to comment Share on other sites More sharing options...
